AF18 Swap on '85 Spree, Throttle Cable Issue
IvyOperator
Post by IvyOperator »
Hi all,
As the title says I am swapping an AF18 onto my '85 spree. I am having issues with the throttle cable. Obviously the stock one will not work on the AF18, since the slide is too small. However, the threaded cap on the carb is not the right size, so an entirely new cable is probably needed. Problem is, any cable I find is just the cable and no cap.
My next solution is to go with a Polini carb, and I am still debating the sizing on that, between a 21mm or 23mm, but if I can keep the stock carb and keep costs down (for now ;) ) then I would want to go with that.
Any suggestions?
1985 Spree
- Scooter Swap Shop Speed Pulley
- MLM People's Sidebleed Pipe
- Decked head
- Tuned stock carb
- Ebay cone filter
- SB50 intake and ceed cage
- Carbon fiber reeds
0U812
Re: AF18 Swap on '85 Spree, Throttle Cable Issue
Post by 0U812 »
Just use the stock Dio carburetor and throttle cable. It may be a little too long so you have to deal with that but how else would you do it?
