AF05E Oil Pump Delete Plug
Got parts to sell? Need a part? Post it here! Honda scooters only.
PcolaBeach
Post by PcolaBeach »
Good morning,
I'm trying to find an oil pump delete plug that does not require any fit modification for a 1992 AF05E Engine, Honda Elite SR SA50 Vin # 3H1AF160-9ND300393.
Thanks everyone!
Re: AF05E Oil Pump Delete Plug
Odd. I'm not seeing these on Ebay anymore. I'm not 100pct positive this one fits your bike: https://www.ebay.com/itm/335938714941
I'd be tempted to 3D print one at this point, but you'd need a high temp filament.
Or DIY. https://hondaspree.net/wiki/index.php/Oil_Pump_Plugs
PcolaBeach
Thank you. I went down the path yesterday of using a bench grinder to remove the oil pump shaft gear teeth. 32:1 Pre Mix. Worked out well. Scooter's running better than ever.
