not sure where I mightput this... need Aero 80 help
Posted: Tue Jul 03, 2007 11:53 am
by e30srthebest
I need to replace the crank seals on my aero 80, but the crank mounted drive pulley/kickstart-gear (not kickstart, its on the crank) wont come off! Ive tried a puller, I've tried heat, I've even stretched "Unstretchable" bolts with the puller. Is there something i'm missing here? help?
Posted: Tue Jul 03, 2007 1:39 pm
by HuskieMobileMan
Dude, I had the same problem. I was trying to pull it off with a timing gear puller and some screws and it just would not go. I plan on rebuilding a NH125 that has the same set up.
What I am going to try to do is get a thick piece of steel, drill a hole in the center of it and tap the same threads as the crankshat into it. Then drill 2 more smaller holes the exact distance apart to fit the pulling bolts into. Thread the steel onto the crank, attach the bolts to the gear and steel and gradually torque down both bolts till it pops.
Posted: Tue Jul 03, 2007 2:56 pm
by Kenny_McCormic
A trick i use to pull flywheels of old 4 stroke briggs engines is to pry on the flywheel and smack the shaft with a hammer they usually pop right off just be careful not to mushroom it
Posted: Tue Jul 03, 2007 8:08 pm
by e30srthebest
tried that too... d*** thing wont budge :evil: :evil:
Posted: Wed Jul 04, 2007 1:39 am
by HuskieMobileMan
I will let you know what happens with my contraption. I will probably get to it next week.
Posted: Wed Jul 04, 2007 6:27 am
by noiseguy
Are you using the puller designed for this? The one that threads into the flywheel, then has a bolt that pushes on the crankshaft?
Posted: Wed Jul 04, 2007 2:30 pm
by e30srthebest
1. im not on the flywheel side of crank case, im on the drive side
2. There are no threads on the gear/pulley half im trying to pull off
3. yes I am using the puller that pushes on the crank shaft, still no workie
I need to replace the oil seals, and this is really satring to * me off...
Posted: Wed Jul 04, 2007 5:38 pm
by HuskieMobileMan
e30srthebest wrote:1. im not on the flywheel side of crank case, im on the drive side
Dude I feel for ya. I got * off as well and decided to take a hacksaw to the case instead. BTW, the case was already f'ed as it was.
Posted: Wed Jul 04, 2007 8:06 pm
by HuskieMobileMan
Got it off my NH125 just now. Used a timing gear puller with the 5/16 flange bolts that came with it. Had to use a dremel to make the bolts fit into the gear. Used the puller without the center screw, just put a couple washers on the crank and fit the puller over the crank. Slid the bolts through the puller and the gear and put nuts on behind. Got everthing straight and then gradually tightened the bolts evenly until *POP* it came off. :D I am going to guess you will need to use 1/4 inch bolts on the NH80.
When it comes to putting it back on, I heated the heck out of it and with the engine on its side I slid it on the crank and used a deep socket over the crank to tap it back on. Once it is in place, have a spray bottle handy to help cool the gear down so that it doesn't heat up the crank and melt the oil seal.
Posted: Wed Jul 04, 2007 11:42 pm
by e30srthebest
thanks for your sympathies and help provided, I will try that last post's suggestion, at this point I am willing to try almost anything.
