sea foam in my spree?
e30srthebest
Post by e30srthebest »
can I put seafoam in my spree, I know it did wonders for my 87 BMW 325is, will it have the same effect on a spree?
chevyguyjay
Post by chevyguyjay »
ive herd of people on here using it, some say it works......others say no way! :o
kurremkarm
Post by kurremkarm »
Yes you can use it. I put a cap in my tank every few fills and it seems to keep my carb clean and the spree running smooth.
islandbayy
Post by islandbayy »
Seafoam is VERY GOOD for your spree. Put 3-5 cap fulls in EVERY Tank of gas for max cleaning action. 1 can will last you a whole summer. Come winter, dump 1/4 can of seafoam in the tank and fill er up. Drive the bike for 1 mile or let er idel for about 15 minutes, pull the battery out and your set for the winter and a single push of the button start next spring!
CHEERS!
http://KmanScooters.com
http://MilwaukeeEV.com
HuskieMobileMan
Post by HuskieMobileMan »
islandbayy wrote:Seafoam is VERY GOOD for your spree. Put 3-5 cap fulls in EVERY Tank of gas for max cleaning action. 1 can will last you a whole summer. Come winter, dump 1/4 can of seafoam in the tank and fill er up. Drive the bike for 1 mile or let er idel for about 15 minutes, pull the battery out and your set for the winter and a single push of the button start next spring!
CHEERS!
Is seafoam a fuel stabilizer as well? If not you should add some stabil or something similar when doing this.
'84 Aero NH125
'84 Aero NH80
'05 Kymco ZX50
islandbayy
Yes, it's a fuel stabilizer as well. Personally, does a much better job then stabil does.
zonker1984
Post by zonker1984 »
Seriously, at some point in time, someone will come up with a spree engine/intake/exhaust problem that you CAN'T use seafoam to help do minor maintenance with. Use seafoam. Use it often.
