Well, I cannot get my 86 Spree to start. The spree stopped running while being ridden at about 15 mph on a dirt road. Now it will only start if it has been sitting for a while, then it will run as long as you don't sit on it... Once you sit on it to try to ride and it shuts off, it will not start again until it sits for a while.
The carb is clean, I have compression etc. Noiseguy helped me make sure everything was in working order, but it still wouldn't run. Does anyone know what the problem could be??
Spree Troubles..
urbansledder
Spree Troubles..
86 Spree
Robert E Kelbe
