It depends. If you're not used to 2-cycle engines it might be more smoke than you're expecting. Yes, a 2-cycle scooter engine will always puff out a thin stream of blue smoke that gets a bit thicker when you lay on the throttle. On the other hand, if you have a dark blue cloud that follows you wherever you ride, then something's not right.
What do you consider crappy oil?Also, I have just got it running after sitting for many years and it boggs out when riding.Not sure if it flooding, running out of gas or some other isssue.It will idle great and rev's nicely on the center stand.But when my son took off on it after a few seconds it started to die, no power.Feathering the throttle helped some.I opened the carb. bowl drain when this happened and lots of gas came out, so not sure if the float and or needle are an issue.Joe
No rust in tank.I did clean the filter.Carb was cleaned.Checked head for carbon(none).Bike idles great.I also cleaned the pulse sensor and magnet on the flywheel of rust.May have had a weak spark.Will also check compression.May get another new plug.Joe
