How to drill airbox?
2fast4u
Post by 2fast4u »
Reading thru the posts I have found a few suggestions about drilling holes into the air filter box to increase power/speed. Yet none of the posts actually go into to much detail on how to do this- how many holes, where on box... and I can't really find any posts stating if it truly helped.
Not the most mechanically inclined, but I do know how to drill a hole so I figured this would be a good place to start with mods.
Any helpful words?
Cold grinding grizzly bear jaws, hot on your heels...
busaridda
huh
Post by busaridda »
Drilling holes in a air box on what kind of moped..scooter.....?
85 spree, 89 elite, honda tristar,700 sabre......and, a suzi hayabusa :)
2fast4u
Post by 2fast4u »
Sorry. An 86 Honda Spree...
Dac
Post by Dac »
remove your air filter cover, get a drill with a charged battery (trust me , battery's help :wink: )
put a drill bit in the drill and drill some holes. now i did this on my elite, for me i did 5 dime size holes and it helped but its different on a spree. i never owned a spree so what for a spree owner to post with how many and what size.
to little holes barely help, but to many and it gets to muck air and bogs
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
2fast4u
Post by 2fast4u »
Have to admit, I'm gonna do exactly as you say and wait for a Spree owner to answer... dime sized holes?!? That's big! But as i said before, I don't know jack about working on this thing yet... somebody, help! :)
Dac
Post by Dac »
ok my holes were not 100% as big as a dime but they were Big. i think i did mine a little to big. 5 was good for mine, i did 6 and had to cap off the 6 hole. it was just to much.
i dumped the stock air filter now and went with a dirt bike UNI pod
it works good but i think i need a bigger jet
dukemartini
Post by dukemartini »
Dac wrote:ok my holes were not 100% as big as a dime but they were Big. i think i did mine a little to big. 5 was good for mine, i did 6 and had to cap off the 6 hole. it was just to much.
was that after the big bore kit? cause if this guys got a stock spree 5 dime sized holes will lean out the motor huge
2fast- introducing more air into the motor with out other adjustments or even upgrades will cause it to run lean which can destroy a 2 stroke engine pretty quickly. be careful
87 Honda Elite S-BASKET CASE PROJECT
88 Honda SB50P-sold but not forgotten
Post by Kenny_McCormic »
yea spree engines are really small and picky they lean out easiley and burn up quickly so be careful and do lots of plug chops
2fast4u
Post by 2fast4u »
Thank you all for the advice, I think I will skip the airbox drilling for the moment based on your comments. The exhaust? Well that sounds do-able unless anyone has similar advice... Thanks for saving my Spree guys.
Your welcome. Drilling the exaust helps ALOT with take off and adds a little to the top speed. Image
2fast4u
Post by 2fast4u »
The pic helps alot but I stil have a few questions:
1) As with the airbox, are there any adjustments or upgrades I need to do so that the exhaust drilling doesn't throw things off?
2) What diameter should my bit be?
3) If I can't reach through to drill thru all of the baffles will only drilling a few hurt?
4) And (last question, I promise) how much louder will this make the scoot- loud enough that a cop will pull me over and question it?
I am really amazed at how helpful and giving of info the members on this board are! Hopefully I will one day be able to do the same...
Thanks again. :D
2fast4u wrote:The pic helps alot but I stil have a few questions:
no not that i noticed best to do a plug chop just to be safe.
2) What diameter should my bit be? biggest you can fit in the hole
3) If I can't reach through to drill thru all of the baffles will only drilling a few hurt? wont hurt probably wont help much though
4) And (last question, I promise) how much louder will this make the scoot- loud enough that a cop will pull me over and question it? its not that loud
Thanks again. :D
your welcome
scooter trash
Post by scooter trash »
don' t drill through all the baffles. 2 strokes need back pressure to run right. drill 2 or 3. it makes the bike loud, depends on how many baffles u drill out
<a><img></a><p><div>Sign by Dealighted - <a>Coupons & Discount Shopping</a></p></div>
86 honda spree repainted ground out intake
02 honda XR100
homemade gas powered scooter
No not all of them i have 4 drilled oout of mine.
