How to drill airbox?
Posted: Sat Jul 28, 2007 12:28 am
by 2fast4u
Reading thru the posts I have found a few suggestions about drilling holes into the air filter box to increase power/speed. Yet none of the posts actually go into to much detail on how to do this- how many holes, where on box... and I can't really find any posts stating if it truly helped.
Not the most mechanically inclined, but I do know how to drill a hole so I figured this would be a good place to start with mods.
Any helpful words?
huh
Posted: Sat Jul 28, 2007 1:01 am
by busaridda
Drilling holes in a air box on what kind of moped..scooter.....?
Posted: Sat Jul 28, 2007 2:46 am
by 2fast4u
Sorry. An 86 Honda Spree...
Posted: Sat Jul 28, 2007 1:36 pm
by Dac
remove your air filter cover, get a drill with a charged battery (trust me , battery's help :wink: )
put a drill bit in the drill and drill some holes. now i did this on my elite, for me i did 5 dime size holes and it helped but its different on a spree. i never owned a spree so what for a spree owner to post with how many and what size.
to little holes barely help, but to many and it gets to muck air and bogs
Posted: Sun Jul 29, 2007 1:10 am
by 2fast4u
Have to admit, I'm gonna do exactly as you say and wait for a Spree owner to answer... dime sized holes?!? That's big! But as i said before, I don't know jack about working on this thing yet... somebody, help! :)
Posted: Sun Jul 29, 2007 3:39 pm
by Dac
ok my holes were not 100% as big as a dime but they were Big. i think i did mine a little to big. 5 was good for mine, i did 6 and had to cap off the 6 hole. it was just to much.
i dumped the stock air filter now and went with a dirt bike UNI pod
it works good but i think i need a bigger jet
Posted: Mon Jul 30, 2007 11:34 am
by dukemartini
Dac wrote:ok my holes were not 100% as big as a dime but they were Big. i think i did mine a little to big. 5 was good for mine, i did 6 and had to cap off the 6 hole. it was just to much.
was that after the big bore kit? cause if this guys got a stock spree 5 dime sized holes will lean out the motor huge
2fast- introducing more air into the motor with out other adjustments or even upgrades will cause it to run lean which can destroy a 2 stroke engine pretty quickly. be careful
Posted: Mon Jul 30, 2007 12:21 pm
by Kenny_McCormic
yea spree engines are really small and picky they lean out easiley and burn up quickly so be careful and do lots of plug chops
Posted: Mon Jul 30, 2007 1:16 pm
by 2fast4u
Thank you all for the advice, I think I will skip the airbox drilling for the moment based on your comments. The exhaust? Well that sounds do-able unless anyone has similar advice... Thanks for saving my Spree guys.
Posted: Mon Jul 30, 2007 3:41 pm
by Kenny_McCormic
Your welcome. Drilling the exaust helps ALOT with take off and adds a little to the top speed. Image
Posted: Mon Jul 30, 2007 11:30 pm
by 2fast4u
The pic helps alot but I stil have a few questions:
1) As with the airbox, are there any adjustments or upgrades I need to do so that the exhaust drilling doesn't throw things off?
2) What diameter should my bit be?
3) If I can't reach through to drill thru all of the baffles will only drilling a few hurt?
4) And (last question, I promise) how much louder will this make the scoot- loud enough that a cop will pull me over and question it?
I am really amazed at how helpful and giving of info the members on this board are! Hopefully I will one day be able to do the same...
Thanks again. :D
Posted: Tue Jul 31, 2007 12:21 am
by Kenny_McCormic
2fast4u wrote:The pic helps alot but I stil have a few questions:
no not that i noticed best to do a plug chop just to be safe.
2) What diameter should my bit be? biggest you can fit in the hole
3) If I can't reach through to drill thru all of the baffles will only drilling a few hurt? wont hurt probably wont help much though
4) And (last question, I promise) how much louder will this make the scoot- loud enough that a cop will pull me over and question it? its not that loud
Thanks again. :D
your welcome
Posted: Fri Nov 23, 2007 1:50 am
by scooter trash
don' t drill through all the baffles. 2 strokes need back pressure to run right. drill 2 or 3. it makes the bike loud, depends on how many baffles u drill out
Posted: Fri Nov 23, 2007 3:34 pm
by Kenny_McCormic
No not all of them i have 4 drilled oout of mine.
