How do you take the piston off ?
Posted: Wed Mar 30, 2005 8:29 pm
by zoom
Do any of yall know.
Posted: Wed Mar 30, 2005 10:36 pm
by vette76
there is a clip on the side of it. pry the clip out with a needle or a very small screwdriver. once this is out slide the pin out of the piston and its out.
Posted: Thu Mar 31, 2005 1:27 am
by burnt_toast
also, be very careful when puting the cylinder back on! i had a broken set of rings one time when i tried it too forcefuly. you need to make sure to use a lot of oil to lube the cylinder and piston, and make sure the rings are pressed in correctly when u slide the cylinder on. all just precautions, for when you're putting the cylinder back on.
btw, if your planning on installing a new piston, then make sure to get your cylinder honed out. its a very important step to make sure the new piston sets in right.
Posted: Thu Mar 31, 2005 8:26 am
by vette76
right. the rings are tempered so they will only flex a little. they are very fragile and can get expensive quick.
Posted: Thu Mar 31, 2005 7:49 pm
by zoom
lol. i hope they dont break. but i was just going to take the piston off to clean were the rings go. but sjhould i just use 2 storke oil?
Posted: Thu Mar 31, 2005 9:15 pm
by vette76
why are you doing that? if its apart u might as well replace the rings for some restored power. and if u take it all apart u will need new head+base gaskets. about $30 total.
Posted: Thu Mar 31, 2005 10:12 pm
by zoom
thats what im doing ive done ordered the gaskets and rings see i broke the rings that were on there forcing them n the jug.
Posted: Fri Apr 01, 2005 4:20 pm
by vette76
oh, been there.lol. that sux.
Posted: Sat Apr 02, 2005 12:15 am
by zoom
just wonderin when u put your rings on did you use that ring spreader tool or di u do it by hand?
Posted: Sat Apr 02, 2005 11:39 am
by vette76
by hand. put one side in the grove and twist very slowly. if it catches or becomes hard.STOP! take your time.
