flywheel
alexhasaspree
flywheel
Post by alexhasaspree »
how do i get the FLYWHEEL OFF and the magnetic coil thats behind it :?:
bad * kids ride bad * sprees lol if their is such a thing
First - remove the 2 bolts holding the plastic fan and remove the fan. Take off the nut in the center of the flywheel.
There are at least 2 options for pulling the flywheel:
1) Buy a specifc puller for your flywheel. That's what the Spree manual shows. It screws into an internal thread just outside the nut holding on the flywheel. Then turn the puller bolt to press the flywheel off the shaft. My puller was about $15-$20 a couple years back.
2) Folks here have used a 2 bolt automobile type puller and used the bolts that thread into the bolt holes for the fan as the anchor for the puller. Don't thread the bolts in too far, they can screw right into the windings on your magneto.
I've never pulled a flywheel with an auto puller.
alexhasaspree
thanx man
ive got that tool for my cr125 i think it will work :!:
