easy mods to do to a spree
8650ccspree
Is there anything you can do to a spree thats pretty easy and can gain like 3mph?
get a long drill bit, put the drill in the end of the pipe and drill though 2-3 baffles.
its not a positive way to add top speed. it helps some people, other people not so. doing this will help take off any way and it will sound allot better
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
8650ccspree
this is a quote from 'Kenny_McCormic'ok heres how to drill out a muffler first get a drill bit as long as the muffler itself (DONT count the downtube! you will never find ine that long) and as big as you can fit in the little hole in the back where the exaust comes out then put the drill bit in the hole in back where the exaust comes out and drill you will run int plates inside the muffler theese are the baffles drill right through them untill you drilled every one just be careful not to drill through the muffler body itself
i dont think you should drill though them all, for a 2-stoke to run right it has to have back compression and if its that open you might loose some. i would go though most but not all
PS:this is a topic about drilling the pipe. this might help you some.
he knows what hes talking about. i mean he helps alot. but almost every topic on this site has his comment in saying 'do a plug chop'.After doing that i would suggest kenny`s favorite thing"plug chop"
this should help you out.
also welcome to the site
