Page 1 of 3
What Kind of engine oil do you use in your Moped?
Posted: Thu Aug 23, 2007 9:43 pm
by No_Stopping_A_Spree
When I bought the elite the guy gave me some Bombardier 2 stroke injection oil which has been doing its job but now that I used the container up I'm going to be switching to Ipone 2 stroke special injector oil..I'm not sure what special injection means but it is made specifically for scooters and it is strawberry scented
it is also synthetic. With near 7,750 miles(when I should have most of the bombardier oil used up) I am planning on running this stuff so I'm planning on making the switch from regular oil to synthetic.
Anyway, just wondering what kind of oil everyone else is using and their luck with it if they'd like to say
Posted: Fri Aug 24, 2007 10:48 am
by Kenny_McCormic
I run some old castrol stuff right now but its really dirty so im switching over soon.
Posted: Fri Aug 24, 2007 11:20 am
by rickc
Pennzoil marine (semi-synthetic) or Honda GN2 (conventional) when available locally.
Re: What Kind of engine oil do you use in your Moped?
Posted: Fri Aug 24, 2007 11:53 am
by GIJoeBob
No_Stopping_A_Spree wrote:When I bought the elite the guy gave me some Bombardier 2 stroke injection oil which has been doing its job but now that I used the container up I'm going to be switching to Ipone 2 stroke special injector oil..I'm not sure what special injection means but it is made specifically for scooters and it is strawberry scented
I'm new here, new to scooters and new to 2 cycle engines so I am sorry if this is a dumb question, but apart from getting laughed at by the other lumberjacks, is there a reason I couldn't use this strawberry scented oil in my chainsaw?
Posted: Fri Aug 24, 2007 5:55 pm
GIJoeBob wrote:No_Stopping_A_Spree wrote:When I bought the elite the guy gave me some Bombardier 2 stroke injection oil which has been doing its job but now that I used the container up I'm going to be switching to Ipone 2 stroke special injector oil..I'm not sure what special injection means but it is made specifically for scooters and it is strawberry scented
I don't see what it would hurt as long as it is mixed at the correct ratio..I just can't wait to run the stuff in my moped myself
Posted: Fri Aug 24, 2007 10:05 pm
by Dac
i buy a container that says " 2-stroke oil " from a * gas station down the road from my house
Posted: Sat Aug 25, 2007 12:20 am
Dac wrote:i buy a container that says " 2-stroke oil " from a * gas station down the road from my house
I do that with my snowmobile..its around 2 bucks for a quart lol..probably going to buy klots this winter though..d*** good oil
Posted: Sat Aug 25, 2007 4:30 pm
by Reydawggy
Castrol sythetic 2 stroke
Posted: Mon Aug 27, 2007 2:07 pm
by myhonda
i get this universal 2-stroke injector oil from this exxon down the road
Posted: Wed Aug 29, 2007 3:28 pm
by skaltpunk
there was a great deal on Honda GN-2 Oil, so i bought 5 quarts of it. seems to be good stuff.
are there any dangers to adding a bit of oil to the gas even when the injector is working?
Posted: Wed Aug 29, 2007 9:08 pm
by Dac
skaltpunk wrote:there was a great deal on Honda GN-2 Oil, so i bought 5 quarts of it. seems to be good stuff.
a dude from honda fed me a line of crap why not to. but as long as you dont add alot you should be good. but for real a little bit is all.
wait for some one else to reply who knows 100%
Posted: Fri Aug 31, 2007 7:22 pm
I don't notice much difference from the bombardier oil to the strawberry ipone (synthetic) it doesn't even smell like strawberry's coming from the exhaust which I thought it would have..the only two things I've noticed are the speed from 25-29/30 is a tad bit faster but that may be because I put in about 2 small capfulls of fuel injector+carb cleaner and my other observation I seen was the oil is used up a little faster, which generally isn't a bad thing.
Posted: Wed Sep 05, 2007 9:46 pm
Dac wrote:skaltpunk wrote:there was a great deal on Honda GN-2 Oil, so i bought 5 quarts of it. seems to be good stuff.
I'm curious to what could be bad about adding a little oil at the gas tank..the only thing I could figure is something with the petcock or it may make it run leaner if to much is addedother than that I don't see what could be bad about it. what did honda end up telling you?
Posted: Mon Sep 10, 2007 6:33 pm
by spreedio
I premix using synthetic Motul 800 2-stroke oil
Posted: Fri Sep 14, 2007 9:31 pm
by Dac
hey fokes, i think i might have found my problem. who i fried my last bore kit.
i dont use 2 stroke injection oil. i just buy a container that says 2stroke. not injection. how bad is this? and should i trow away what i got and get all new injection oil?
[the dumb * at honda said it could cause it to fire before the plug sparks. it could pre-combust like Diesel motors. he had no proof to back it up thats just what he said. when i asked him if he cared to explain he said 'thats just what i heard.']
