still cuts/bogs out
snikro
still cuts/bogs out
Post by snikro »
Well I bought an actual air filter, installed it, and the throttle still cuts out when I ride it and try to give it a good amount. The problem is better since I used the real filter instead of the one I made out of a sponge (see other thread), but just a little. I got it to go real fast with full throttle ONCE with the new filter, but only for a second and then it started cutting out. Also, I'm getting a lot of white smoke out of the exhaust. The problem seems to get worse as the engine gets hotter - if it starts getting really bad and bogging out on just a little throttle, if you let it sit and idle for a minute it's better when you start off again, but quickly gets worse. Ideas?
Post by Kenny_McCormic »
do a plug chop
edjo
Post by edjo »
Kenny, you need to change your name to "Plug Chop Kenny". :D :D
88 elite SA50
07 DRZ436sm
05 FJR1300a
05 Dr200se
Yes but there is so much you can tell about a 2 stroke engine just by looking at the plug.
snikro
Post by snikro »
Ok well as I think I said before I can't possibly do a plug chop because if I hold it at full throttle it will start to bog within seconds, and if you keep holding it there the engine dies.
gsemack
Post by gsemack »
Whats a plug chop?
edjo
Post by edjo »
Look in the technical document section, there is all sorts of really good info in there.
88 elite SA50
07 DRZ436sm
05 FJR1300a
05 Dr200se
snikro
Post by snikro »
Any more ideas? I am thinking its an air issue, because the new factory air filter (probably more breathable than the homemade one) seemed to help the problem a bit. Also, exactly where are those notches to make it run more rich/lean?
snikro
Post by snikro »
I tried riding it with the air filter cover off (filter still on), and the problem was a little bit worse. I put it back on and then adjusted the air screw to the right amount of turns in case it was off, and that didn't really hurt it but didn't seem to help either.
Also a thing to note, when you're giving it a lot of throttle and its bogging out, sometimes there will be a couple of very small what sound like backfires, and more white smoke comes out. If you let it sit and idle for a minute the smoke pretty much goes away, but when you start out riding it again after a minute there is a good amount of white smoke.
Restricted exhaust maybe? I have no idea :x
Dac
Post by Dac »
for once i dont know ether
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
pull out the spark plug and look at it after some riding
jeremydde
Post by jeremydde »
Is your float too high in the carb?
2000 Honda Dio
Malossi 72cc Bore
28mm Oko Carb 45 Pilot & 132 Main
Phongeer Long
9 to 1 Gears
Parmakit Variator
1500 RPM contra spring
Kuka Clutch w/Polini green springs
Koso Digital Tachometer w/CHT
Dac
Post by Dac »
Kenny_McCormic wrote:pull out the spark plug and look at it after some riding
i dont remember who said it but {your name should be changed to 'plug chop kenny'} is true
snikro
Post by snikro »
Something I forgot to mention - when the bike is running and you put your hand over where the spark plug is coming out, you can feel little puffs of air with every revolution, coming out probably where the spark plug hole is, and they increase as you throttle up. It wasnt much so I always thought it was nothing, but is this something to worry about?
Compression loss??
Dac
Post by Dac »
any chance you are just felling your cooling system?
you moped is air cooled. therefor has a cooling fan . it forces air up around your cylinder. so you might be able to fell it there. just an idea
