1985 Spree wont start getting some spark
willie2124
I just got a 1985 Honda spree. Good shape the guy said he had a new carb and bat. put in last year and a few months later it died and would not start. Its in good shape and he just gave it to me. I dont see a spark on the plug so i put screw driver in the coil and it shocked me but it was not a strong shock. how strong should it be? I need help I want to get this thing on the road!!!!
1985 Honda Spree
2006 Honda TRX 450R
2006 Honda TRX 90
2006 Honda TRX 450R
2006 Honda TRX 90
Martin Fox
Spark
Make sure you are using the right NGK plug, try a new one to make sure. I believe you should be getting a strong blue spark, which you can check by removing the plug from the cylinder head and hold it close enough to the frame to get a spark. I had a weak spark condition which was improved by cleaning the rust off of the little raised rectangle on the flywheel that serves to time the ignition. A little light sanding cleaned off the rust and made the spark considerably better. In that particular episode I had good spark, good gas/air and it still wouldn't start, although it sounded like it wanted to. I sprayed a mixture of liquid soap and water on the cylinder and head and discovered that air was being compressed but leaking out of where the sparkplug connects to the head. A new plug washer and correct torque on the plug solved the problem. Good luck!
Martin
Martin
