horn
- No_Stopping_A_Spree
horn
anyone know where I could buy a new horn online..I'm thinking something different than the high pitched normal horn..The problem is I can't find any, although I haven't done much searching. The reason why is because my horn only works under a certain tempurature and doesn't when it is warmer
and I want a working horn but thing something different would be kinda neat lol
- CharlotteSpreeRider
i helped rewire a stereo system in a jeep once, for his base we put a Yamaha jog horn. every time the base 'hit' it honked. it was funner then *.
thinking back im wondering if a small speaker would work as a horn. if so how would it sound?
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
that would be funny to seeDac wrote:i helped rewire a stereo system in a jeep once, for his base we put a Yamaha jog horn. every time the base 'hit' it honked. it was funner then *.
as for your question I have no clue
So my horn ended up dieing today
and I'm looking online for a cheap horn..I usually can't tell how many prong thingys there are and the elite one has one prong (so one wire that connects to the horn..green I believe) what would I do If I got a two pronged horn by accident?
I'd explain what I meant by prongs but I'm hoping someone understands what I'm talking about because I can't explain it all to well
It wouldn't sound like a horn. It would just make a single pop when you pressed the button. A horn isn't a speaker.No_Stopping_A_Spree wrote:that would be funny to seeDac wrote:i helped rewire a stereo system in a jeep once, for his base we put a Yamaha jog horn. every time the base 'hit' it honked. it was funner then *.
I would recommend something like these-
which I had on my BMW. This horn can knock birds out of the air.
Hella Twin Supertone Horn Kit for $65.
it had 2 prongs, and a speaker has 2 wires. i set it up like i would a speaker. it just 'greeee' noise. when the base hit it would honk. i swear. get a yamaha jog horn and try it your self.It wouldn't sound like a horn. It would just make a single pop when you pressed the button. A horn isn't a speaker.
duh..that makes sense..I was wondering why it was sparking were the bolt held it on lolMySpree wrote:the second is jsut a ground. the elite uses its case as a ground, but most horns use a ground wire mount.
I'd like to get this air horn..139 decibles and can be heard from 3 blocks away..its only 40 bucks too
anyway thanks myspree..after seeing a new one from honda was $25 and seeing some for $5 but having two prongs i didn't want to go to the honda one
I'm sure it worked, but that is when you wire a horn to a speaker output, not a speaker to a horn output.Dac wrote:it had 2 prongs, and a speaker has 2 wires. i set it up like i would a speaker. it just 'greeee' noise. when the base hit it would honk. i swear. get a yamaha jog horn and try it your self.It wouldn't sound like a horn. It would just make a single pop when you pressed the button. A horn isn't a speaker.
A horn just works off of electrical current. Just about any current will do provided it is enough to move the element inside. A speaker works via a modulated electrical signal where the varying frequency of the electrical signal makes the speaker create sounds of varying frequencies.
A horn is designed to create a sound of only one frequency and as such does not need a modulated signal. That's why the horn in your story still just honked and did not create the other sounds in the music.
is there some special way to adjust these? Mine has a adjustable bolt where the nut goes on that can be brought in or out and I can get it to work occassionally but once I set it back up it won't work again..just curious, either way I'll be buying a new one today but would like a partial horn at the least concidering people don't know how to drive
