I have 97 elite and I am looking to get some higher top end speed. I want to remove the clutch outer pulley plate. I many years ago drilled out the header exhaust after the dealer told me about it. I have the crankcase cover off. but i need to remove the nut. I don't have an impact wrench or a universal holder to hold the flywheel. What is a poor man's way of doing this? In the picture below is this the correct starter drive gear I need to remove to get to the clutch plate?
Can't get any poorer than this!
I would bang the ratchet with an extension rather than just turn it as it puts less stress on the bolt holding the wrench.
2000 Honda Dio
Malossi 72cc Bore
28mm Oko Carb 45 Pilot & 132 Main
Phongeer Long
9 to 1 Gears
Parmakit Variator
1500 RPM contra spring
Kuka Clutch w/Polini green springs
Koso Digital Tachometer w/CHT
2000 Honda Dio
Malossi 72cc Bore
Phongeer Long
9 to 1 Gears
Parmakit Variator
2000 Honda Dio
Malossi 72cc Bore
Phongeer Long
9 to 1 Gears
Parmakit Variator
If i had to take my crankcase off many times I think I would build one of those as well. Since, I have a full machine shop at my disposable if need be. the later pictures are sweet little device.
edjo wrote:You have a full machine shop at your disposal but no impact wrench??
I am sure there is a impact wrench in there somewhere. But mainly it is a machine shop. I know main machine shops that don't have impact wrenchs since they just have mills, cnc's, lathes(sp), etc like the shop I have access to. But, the main reason I wanted a cheap way was the moped is located at my house and not the shop. So I don't have an air line at my house which is what the impact wrench would have been. Also, I rather work on the moped at home then a place I spend 70 hours a week.
yeah i hear you there. i copped down my mirrors like 2inch's. my plain was to do it with my grinder then rebend. my grinder was s*** so i had to take it into work. i hate doing stuff like that.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
