jayrey0910
Posts: 25 Joined: Thu Aug 02, 2007 6:03 pm
Post
by jayrey0910 » Fri Oct 12, 2007 7:04 pm
spree ran 32-36 in warm waether now its cold and it goes 27-31. is it because of the weather?
Dac
Posts: 3340 Joined: Sat May 05, 2007 5:58 pm
Post
by Dac » Fri Oct 12, 2007 7:53 pm
possibly. my elite seems not to be hitting its top speed ether.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
edjo
Posts: 113 Joined: Wed Aug 29, 2007 10:50 pm
Post
by edjo » Sat Oct 13, 2007 12:09 am
In the cold they will run leaner.
88 elite SA50
07 DRZ436sm
05 FJR1300a
05 Dr200se
Dac
Post
by Dac » Sat Oct 13, 2007 12:15 am
thats what i thought. but its cool out and mine is smoking more. (so it seems)
smoke mean rich. and lean is mean, i would be going faster not slower. im confused
CharlotteSpreeRider
Posts: 710 Joined: Tue Sep 11, 2007 2:13 pm
Post
by CharlotteSpreeRider » Sat Oct 13, 2007 1:41 am
It also depends on the relative humidity of the climate. If the humidity is very low, what you see as "smoke" might actually be just steam, like when you can see your breath on "very" cold days. (I live in southern NC now, but I'm from FL, so this whole "cold" thing is still new to me. 80 degrees on New Years Day is not at all unheard of in Orlando.)
It's gotten quite a bit cooler in Charlotte in the past week, down to mid-40's in the morning when I'm leaving for work, and I've noticed my Spree produces alot more visible exhaust in the mornings than it did 2 weeks ago. Once it's good and warm though, it works pretty much just like when it was almost 100 degrees.
-aseigler
Posts: 4957 Joined: Sun Apr 16, 2006 11:51 am
Post
by Kenny_McCormic » Sun Oct 14, 2007 11:47 am
The cold air is denser to a point where you must richen the carb settings..
Dac
Post
by Dac » Sun Oct 14, 2007 11:48 am
i can just set the carb. needle to the bottom-est setting ?
Post
by Kenny_McCormic » Sun Oct 14, 2007 11:49 am
One notch down should be good.
Dac
Post
by Dac » Sun Oct 14, 2007 12:20 pm
ok thanks for the tip
Farfignugin
Posts: 489 Joined: Mon Jul 23, 1973 10:24 am
Post
by Farfignugin » Sun Oct 14, 2007 8:49 pm
You know it's cold out when you stick your head in the freezer to warm up after being outside.
Dac
Post
by Dac » Sun Oct 14, 2007 9:22 pm
i remember all that from last year, its cold out now, i dont want to even be here in a month
