Your sucking air from somewhere. Check all the seals around the carb and around the case. Spray carb cleaner around the seals when the engine is running and see if the motor revs up. Or the carb is still gummed up, have it acid dipped and blowen out with compressd air.
thats....
thats what my new elite is doing. What type of air filter do you have? a yesterday my filter fell off. as i was going i put my finger over half of the carb. opening and it took off. i have had no luck after that, but that is the SAME thing mine is doing.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
im thinking of getting a few parts ( CMR 72cc kit - $100.00 ) my question is are you sure that this will fix my problem? theres a few other things im thinking about getting with this. this would be the last of my money . i dont want to get this and find out its something else.
also does the videos he posted seem like a compression problem to you? that is 100% same as mine.
Kenney is right. Thats your starting point. When that thing did rev up it sounded great, that tells me the rings are good. Make sure your running injector oil too. Pre mix oil in your oil tank will lean it out also.
Well regarding intake leaks, I looked around the air case and I could only find really one questionable spot. This is where the case connects to the carb:
If thats the stock aero engine you can replace it with a dio, they never made a 72cc bore kit for the aero only a malossi 65cc kit and no more 8 to 1 gears are offered, the engine starts & runs so you have compression.
stillspeeding wrote:If thats the stock aero engine you can replace it with a dio, they never made a 72cc bore kit for the aero only a malossi 65cc kit and no more 8 to 1 gears are offered, the engine starts & runs so you have compression.
but he dont want a new engine. he wants to make what he has run right....
Every * Time Some One Has a Problem You Tell Them To Get A New Motor. PEOPLE DONT WANT NEW MOTORS.
ok i ran my 92 for a few months with only one ring and a half blown cylinder. it had hardly any compression at all. so no. if the engine runs it dosnt mean its got compression.
