porting reed vaulves
Posted: Tue Nov 06, 2007 3:38 pm
by jayrey0910
will making reed vaulves larger by using a dremel will it help top speed?
Posted: Tue Nov 06, 2007 3:47 pm
by Dac
no.
the reeds are perfect the way they are. you can do anything you want to the reeds and it wont make a d*** difference. However trying this is stupid also. any gap (no matter how small ) will kill your motor and you will have to buy need reeds. all around its not a smart idea.
Posted: Tue Nov 06, 2007 5:18 pm
by Kenny_McCormic
You can use, I think it was SB50, intakes and reeds for higher flow, just grinding that sharp turn out of the intake is supposed to help alot.
Posted: Tue Nov 06, 2007 6:23 pm
by Dac
yeah that trick is in the advance tech. doc. part of this site. but thats more less the intake trick, reeds just happen to play in
Posted: Thu Nov 08, 2007 1:18 am
by stillspeeding
Unless you have a full blown stroker don't even think about it, even then its not proven, a quality bore kit comes with a flow chart for max performance so what makes you think you are better than them
Posted: Thu Nov 08, 2007 5:07 pm
by edjo
Probably the same thing that makes you think you are better than everyone. A general lack of knowledge and no sense of direction. Fortunately for most of us its just scooter related stuff. You on the other hand seems to possess these traits in your day to day interactions with other human beings.
