Page 1 of 8
2001 honda elite s (dio) Stroker 100cc on spree
Posted: Thu Apr 14, 2005 4:59 am
by diosoljah
Hey guys heres my spree
heres the specs:
51mm Round stroker cylinder (Exhaust port, and transfer ports ported)
51mm Stroker Crank
crankcase (Block) has been ported (Boost port and intake port) and machined to fit the oversized counter weight on the stroker crank
Double reed manifold intake
28mm Oko carb (Similar to the 28mm pwk keihin)
Kitaco high speed pulley and ramp
aftermarket centerspring bearing kit
7:1 gears (mallossi)
aftermarket racing coil
aftermarket racing cdi
red daytona high flow fan
using NGK BPR8HSA Sparkplug gapped to .025 inches
premix oil using motul 800 50:1 gallon ratio
Posted: Thu Apr 14, 2005 9:19 am
by darat
OMG That thing is the ship dude. u got to tell us where u got all of that stuff. d*** that thing should do like 80Mph
Posted: Thu Apr 14, 2005 12:24 pm
by vette76
wow. what the top speed on that?are the dio parts on the original spree cases? or is the whole rear end dio?
Posted: Thu Apr 14, 2005 5:42 pm
by Ozzimo
nice man.
Posted: Thu Apr 14, 2005 6:02 pm
by diosoljah
I live in hawaii and and theres a multitude of shops that modify mopeds mainly the 1994-2001 Honda Elite S which has a dio motor and Jog. As for my Honda Spree, The Entire block is a 2001 honda Elite S motor (Dio) Keep in mind that honda released this motor from 94-2001 and is the most sought after motor to modify here. After Stroking the motor (51mm cylinder, 51mm stroke=104.22679 CCs) and porting block (intake and boostport) porting the cylinder (Exhaust, and transfer port) Greatly improved Mids and High end but from this point the low end was sacrificed and to improve the low end Ive jetted down on the pilot jet and decreased the weights in the high speed pulley, ive put a centerspring bearing to stiffen out the 1500 centerspring to a 1800, increased spark by installing a racing coil and racing cdi by doin all this it reved higher to improve the low end. and as for top speed 100mph plus
heres the shops (These shops are located in Honolulu, Hawaii):
KS Cycles (This is a new shop, try calling honolulu local operator for number)
Botek Mopeds (808) 943-1868
VT Cycles (808) 593-7733 (1251 S. Beretania St. Honolulu, HI. 96814)
Call for Keoni or Steve
Quik Fix Cycles (808) 536-2277 (725 Auahi Street Honolulu, HI 96813)
Call for Frank (Owner)
Cycle Imports (808) 952-9253 (847 Mccully St, Honolulu, HI 96826)
Call for George (Owner)
Glenns Cycle (808) 732-5547 (3703 Waialae Ave, Honolulu, HI 96816)
Posted: Thu Apr 14, 2005 6:36 pm
by vette76
i know someone who has a jog. hes put about $1000 in to it all in performence parts. but he lives in dr.
Posted: Fri Apr 15, 2005 4:16 pm
by diosoljah
My advice to you all is to first try to fit a dio (94-01 elite S SA50) motor first on the spree. I Can put up some pics on how to start because Im planning on building another beast Spree Dio, Once you have it on the frame and aligned you can do the first stage of modification and thats to get a high speed pulley kit, about $50 then change the jettings and remove the restrictor washer in the exhaust using a step bit or dremel, plug the oil lines and then premix with 2-stroke synthetic to 50:1 ratio per gallon, tune the carb then boom go 40-45 mph.
Posted: Mon Apr 18, 2005 3:06 am
by diosoljah
has anyone else attempted to swap or thinking of swapping engines? Im planning one building a drag style spree with a stretched style dio motor, Im thinking of a stroker motor but watercooled, possibly a 54mm watercooled cylinder kit and a 54mm Her II stroker crank putting out 124cc, its in development but not sure yet, post up some suggestions guys, any input
Posted: Sun May 01, 2005 5:15 am
by diosoljah
heres another example of a Spree with a Elite S motor, I dont know the guy but hes from where Im from (Hawaii). its also a stroker and is for sale but expensive (click on link below)
http://www.islandpreviews.com/main/modu ... d_id=32100
Posted: Sun May 01, 2005 10:39 am
by burnt_toast
man that is a ridiculous amount of performance in a spree! 8O
Did you have to strengthen the frame any? I've heard that its not really made to handle those types of speeds.
Sweet job, btw. That engine looks badass!
Posted: Sun May 01, 2005 12:48 pm
by Spreed
My question is: How do you stop on those brakes!?!?!??
Posted: Sun May 01, 2005 2:06 pm
by diosoljah
good point, its difficult to stop at those high speeds (60-100), Ive talked to some guy in japan about disk brakes conversion and it is possible, those are my next mod on the bike. As far as speed is concerned its scary to go 60 on a spree, I just built this bike for the * of it
Posted: Sun May 01, 2005 4:03 pm
by vette76
i am kinda taking someone elses words here but try forks off an elite. they will bolt up and be a lot more stable at high speeds.
Posted: Mon May 02, 2005 10:02 am
by noiseguy
Besides swapping forks (from an Aero or Elite,) you way want to lean back the head tube about 3 degrees. MRFIXIT did this to his, it will make the scoot more stable at speed. Heat, bend, reinforce.
Posted: Mon May 02, 2005 12:15 pm
by vette76
i was wondering if the body will still fit after that.
