After the winter, spree does not start
Posted: Thu Apr 14, 2005 12:09 pm
by hondaspree84
I have a 1984 Spree. Had it worked on last summer -- worked great. I made a huge mistake and did not drain the gas over the summer.
New filter, new petcock valve, cleaned carb.
I did get it running for a few minutes -- and then bogged out -- couldn't get it started.
I cleaned the carb. I can get it started for one second only by putting some starting fluid into the air chamber -- and will not hold the start.
I drained all of the gas and put fresh gas in.
gas is running through the carb.
is it possible the engine has too much gas in it? If so, how to drain that?
Thanks to my fellow members!
Posted: Thu Apr 14, 2005 12:21 pm
by vette76
if u dont ahve a filter that is the problem. to drain gas use the screw at the very bottom of the float bowl.
Posted: Thu Apr 14, 2005 12:51 pm
by hondaspree84
I do have a filter and all the gas has been drained out.
won't start after winter
Posted: Thu Apr 14, 2005 8:16 pm
by hondaman
I just add stabel to the gas before i put it away for the winter and i have not had problems starting it. That old gas if left untreated can really gum up your carb.
It sounds to me like your jets are clogged. Clean the carb again and do a thorough job on the jets. Check to make sure your float is operating smoothly.
Posted: Thu Apr 14, 2005 9:20 pm
by vette76
sounds good to me.
