Final drive fluid/ gear oil or 10w-40?
rpm9001
Post by rpm9001 »
What do you guys use? I drained mine and it was gear oil , looked in the book and it says 10w-40 I will do what the book says, but It was 100%gear oil that I drained. super thick and no mistaken the smell. What do you guys use?
chevyguyjay
Post by chevyguyjay »
i guess its what U prefer.....i always use 80/90wt in mine. :wink:
~2004 Geely Fashion~
Dac
Post by Dac »
thats to thick. it will slow you down. allot of people put thicker s*** in there thinking its what belongs since its gears. how ever 10w30 or 10w40 is what you should put in there.
I talked to a guy at honda about it.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
No_Stopping_A_Spree
Post by No_Stopping_A_Spree »
Dac wrote:thats to thick. it will slow you down. allot of people put thicker s*** in there thinking its what belongs since its gears. how ever 10w30 or 10w40 is what you should put in there.
I concure [agree]
chevyguyjay
true....i agree dac, i have read the manuals on what oil to put im there, its just my prefrence on what oil to put in there. I think being that they r gears.....put gear oil in there. but hey.....what do i know?! lol :wink:
Post by Kenny_McCormic »
Stock engines 10-30, 10-40, or plain 30
Upgraded motors should run gear lube IMO because its working hard enough that it will heat up and not slow you down.
Dac
Post by Dac »
that is true.
i can only imagen 90 in there mid winter. Motor revs all the way but the scooter just cant get moving. even on stand. lol
rpm9001
Post by rpm9001 »
Filled it with 10w-40 It had gear lube in there, It drained super slow. I filled and dumped it 3 times with warm 10w 40 till it was clear oil.
DrZ34
Post by DrZ34 »
3 words Royal Purple Gear Oil
ok that was 4
but just use it those gears work to hard to use motor oil,
gear oil has ep additives (extreme pressure), which is usually a sulfur/zinc/moly mishmash, hense the * smell of non syn. gear oil
oh and no sludge of death when its cold outside
Green for tha' money gold 4 tha honeys :roll:
MichiganEd
Post by MichiganEd »
I always do what the manufacture says!!!!!!!!!! I really believe the engineers know alot more than I do......AMEN.
chevyguyjay
yea, for stock bikes, and yes.....they probably do. :wink:
MichiganEd
His scoot is stock......................so do what the manufacturer sez to do. Seems pretty simple to me.
rpm9001
Post by rpm9001 »
I agree... if gear lube was better, Honda would of used it.
55bore
Post by 55bore »
We used to call stock oil fish-oil, because in the 80s, the oil smelled fishy and was only good for break-ins.
Even if your bike is stock, treat it to some synthetic multi-weight gear oil. Use the same thing that dirt bike guys use in your area.
If you're running a performance moped, then break in with regular gear oil and then go synthetic. Good synthetics have 3x the shear strength of natural petroleum oils = less friction, less wear, better performance and longer life.
You don't have to change gear oil very often, so it's worth the few extra bucks.
Dac
Post by Dac »
ok, im kinda mid-break in on my 96 elite. ( new bore, new gears) As of right now im running 10w 40.
So your saying that when im done i should switch synthetic, what thickness?
