bogs at full throttle
coldfusion
Post by coldfusion »
hey guys when i ride my moped i give it full throttle it wants to bog out and die any ideas
Post by Kenny_McCormic »
Do a plug chop, you could be burning that little motor up. Knowing what moped you have might help.
coldfusion
86 hond spree wuts the color scale
Dac
Post by Dac »
White= lean
coco brown= perfect
Black or wet = rich
this is perfect as perfect can be.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
ignore
Last edited by Kenny_McCormic on Wed Jan 02, 2008 12:43 pm, edited 1 time in total.
Be sure to use a fairly new sparkplug old ones dont read well.
coldfusion
how many turns once i tighten the air fuel screw do i turn it out and wuts the gap
Dac
Post by Dac »
all type of information can be found in the Technical Documents part of this site. { IE-here is your anser }
Im sure you can the answer in there along with the answer to almost any question you got.
Welcome to the site man.
Dac
Post by Dac »
and Kenny, when will you learn that the 'backspace' key don't work on this website. (or almost any forum) you have to use the edit button. :lol:
Ya my bad.
chevyguyjay
Post by chevyguyjay »
yes sir.......that is a perfect running engine by the color of that plug. :wink:
~2004 Geely Fashion~
55bore
Post by 55bore »
Kenny_McCormic wrote:Be sure to use a fairly new sparkplug old ones dont read well.
Old ones read better than new ones. Just make sure that you use the color of the plug when you put it in before you chop it.
Really? You would think the gunk would build up and it woulnt read well but i guess that gunk is whats getting colored.
