If you have wrenches with the traditional stamped markings (not the cool, new fancy laser etching) then you know that it can be hard to tell one wrench from another.
I take black crayon and rub it into the number indentation and then wipe off the residue to make each wrench have an easy to read black number.
Here is a comparison of a plain wrench and one with the crayon-
GIJoeBob wrote:If you have wrenches with the traditional stamped markings (not the cool, new fancy laser etching) then you know that it can be hard to tell one wrench from another.
I hope that helps!
Now that is a good solid tip, I was thinking permanent marker, which do you think will hold better?
