Engine will not shut off once keys removed from ignition!
Posted: Thu Jan 10, 2008 5:58 pm
by ManicGTI
Firstly, hi all, first post!
1986 Vision NE 50 MF, Not a spree i'm afraid, but I believe it's pretty much identical!
It hasn't been run in 6 years so I cleaned the carb, tank out etc and have got it started, but when I turn it off and remove the key it keeps on running for a minute or so and eventually dies!
I have added an inline filter sitting vertically in the fuel line from tank to carb as I found some debris in tank when I cleaned it out. Could it be residual fuel in this that is keeping it going?
Dave
Posted: Thu Jan 10, 2008 7:55 pm
by uspmale
Unless the cylinder is really car boned up, I suspect your ignition switch is bad or shorted.
Pull the switch off and check with a multi-meter.
Posted: Sun Jan 13, 2008 6:48 am
by ManicGTI
Thanks, i'll check the ignition switch.
Would a carboned up piston cause the same problem then?
I'm a car man normally, 2 strokes are new to me :oops:
Dave
Posted: Sun Jan 13, 2008 10:50 am
by uspmale
Yea, hot spots created by the carbon build up can fire unburnt fuel.
If the swich checks out OK, then pull the head and look for carbon deposits.
Posted: Tue Jan 15, 2008 11:54 am
by DrZ34
uspmale wrote:Yea, hot spots created by the carbon build up can fire unburnt fuel.
Also known as " deiseling", sometimes acompanyed with running backwards
Posted: Tue Jan 15, 2008 5:36 pm
by ManicGTI
update...When I pull a spade off the coil, it does die out.
Assume this implies ignition problem?
Posted: Tue Jan 15, 2008 7:15 pm
by uspmale
Yes, you just eliminated the spark.
Your switch is stuck in the on position.
Probably you will have to change it out.
Posted: Mon Jan 21, 2008 7:15 am
by ManicGTI
Sorted 8)
Geen wire had broken on back of Ignition. Resoldered them all for peace of mind.
Now Runs and stops fine, thanks for the tips!
Onto the next problem...leaking carb :lol:
