Pics of the scoot b4 and NOW
da-scoot
Post by da-scoot »
Buddy's Kid playin on da scoot
My girlfriend and Gage on da scoot
Tore the body panels off to prep for paint
The decal that was on it
The Chamelion Paint Job... Not to shabby
Body filler
Got the parts wet sanded
Middle section taped off for custom fiberglass speaker encloser
Truck sanded... custom panels will be made to flush in the amplifer and coverter...
Dac
Post by Dac »
Dude, i cant wait to see this thing done.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
darat
Post by darat »
yeah its going to look good.
wikked_spree57
Post by wikked_spree57 »
He's doing the type of things I like to do with my own... paint... I have to say for spray paint that does not look bad at all. The Powered by Honda is sweet, Im looking for Yamaha tags for my current projects. I want to get them both fixed up and get a 94+ Elite :wink:
1983 Yamaha XC 180 - Bought barn fresh in mint condition and 254 miles. Best bike I ever owned :)
da-scoot
Post by da-scoot »
My inspiration for my scooter is my car..and my bike..
Ive been ridin hondas for a long time.. my first honda 4 wheeler was a honda 70 i got when i was 6
Ive never had any major problems with my hondas so i stuck with it...
i got into the import scene.. but luckily after the body kit and HUGE wing era...
I now have a 1993 honda civic DX with a b18 LS VTEC swap..
Im pretty proud of the work ive done to the car so i wanna continue it with my honda scooter
da-scoot
Post by da-scoot »
wikked_spree57 wrote:He's doing the type of things I like to do with my own... paint... I have to say for spray paint that does not look bad at all. The Powered by Honda is sweet, Im looking for Yamaha tags for my current projects. I want to get them both fixed up and get a 94+ Elite :wink:
using paint from a aersol can.. can turn out nice as long as you take the time to prep the plastic....
Scuff the surface... use a flex primer..(a MUST) your base coat... and since its on plastic i sprayed an couple xtra coats of clear.. a lil wet sand... 20 min buff and wax!
Now thats if you want a fully finished look... on my chamelion job.. i didnt wet sand and buff...
That paint was that 3 stage paint from Wal Mart in the packs...
layed that decal over it and called it good... now.. the white.. was just base white... and Autozone sells a clear coat that has metalic flake in it... just spray it over any base color to give it that metalic look...
FYI: Flat black with that metalic clear is sweet!!
da-scoot
Post by da-scoot »
This is a pic of My car and motor in it... my main inspiration for buildin my scoooter
So.. my scooter will be HONDA FACTORY Champion white
The rims above are the rims i have purchased 4 my car but have not put on yet... so i will Paint my stock SB50 rims the same way...
Along with the white.. i will have some factory honda civic parts on my scooter... JDM Honda Badges will be on the front and rear
for the rear.. i plan on shavin the holes where the rack and rear tail light assembly go...
Honda Civic Side Markers will be flushed in on the rear of the scooter for the turn signal..
Also i have purchased a side mount liscence plate frame with tail/brake light
As you seen b4 i will be makin a custom fiberglass speaker encloser... this will house two Alpine Type S 5 1/4" speakers...and also a volts Meter gauge
Music will be played through any MP3 player i have... since an MP3 has such low output signal... a in line output driver will be needed to boost signal to the mini "500 watt" amplifer i have... true watt is about 75 watt out put.. good enuff to make the Type S sound good!
As you can tell by the progress pics.. Im not too far on it... the enclose will take some time... then the paint... after that... it should go quick I have all my parts ordered
the mirror i have for it
The grips i got for it.. to stay with the CF theme..
CF will only be used on small accent pieces..
SOOOOOO... what you guys think?
Sound like it should be pretty cool... far from stocK!!
Dac
Post by Dac »
d***!
now i really cant wait to see this thing done!
Post by Kenny_McCormic »
You might have problems running that amp for long, I would highly recomend you install a switch inline with the headlight so your electrical system is less loaded down.
da-scoot
Post by da-scoot »
Kenny_McCormic wrote:You might have problems running that amp for long, I would highly recomend you install a switch inline with the headlight so your electrical system is less loaded down.
Yes i was thinkin about the chargin system for the battery.. I will have 2 switches.. one cut off switch to the head light and one cut off to the amplifier... That is another reason why im installin a volts meter so i can monitor the voltage so i dont overload the system and blow my amp up...
MariePhotography
Post by MariePhotography »
This'll be an interesting scooter.
5/14- Repainted, has speedometer, goes up to 25 mph so far.
5/8- Ordered Speedometer cord and Mirrors
5/1- GeekMo Renamed Grymm
1/21/08- Proud owner of a 1985 Honda Spree.
