1997 versus 2000 Elite
Posted: Tue Feb 19, 2008 5:40 pm
Is the 1997 Elite the same scooter as the 2000 Elite ?
Thanks,
Happy
Thanks,
Happy
Keeping Spree Elite Aero 50cc and Gyro Alive!
http://hondaspree.net/hondaspree.net/phpBB3/
http://hondaspree.net/hondaspree.net/phpBB3/viewtopic.php?t=4728
...feed the needyburnt_toast wrote:yes indeedy
Thanks to all?? do all the transmission part interchange too?Kenny_McCormic wrote:Im pretty sure 94-01 are all the same internally.
Dac wrote:all honda elites 50's...
94-01
are the same bike part for part. The only and only difference is the some bikes are restricted and some are not. All parts are interchangeable.
someone told me the part of the frive is double bearing instead of 1 was 2 till 98 i guessstillspeeding wrote:There was a washer eliminated in the final drive gear either in 97-98 everything else is the same.
I told you on the other forum...happyman wrote:someone told me the part of the frive is double bearing instead of 1 was 2 till 98 i guessstillspeeding wrote:There was a washer eliminated in the final drive gear either in 97-98 everything else is the same.
that was nice of you . now others also know it... its great!veedubh20 wrote:I told you on the other forum...happyman wrote:someone told me the part of the frive is double bearing instead of 1 was 2 till 98 i guessstillspeeding wrote:There was a washer eliminated in the final drive gear either in 97-98 everything else is the same.outer gear over only.
87,88-93,94-98 2 bearing cover & 1 bearing on 99-01 only...
94-01
