84 spree wont start
Posted: Wed Mar 19, 2008 6:45 pm
hi, I just bought two 84 honda sprees, one starts and runs fine but the other doesnt start.
some of the problems ive noticed.
1. the starter pinion does not extend out far enough when the starter is turning it over. could this be a bad pinion? bad starter? both? even when I hook the battery up to a charger it doesnt make any difference.
2. the engine has WAY more compression than the other scooter. i took the plug out and was able to turn it over easier but it puked out a bunch of very oily gas.
If I extend the pinion gear out by hand out to that pully gear it will not turn over.
what should I try to get this thing running?
