clutch springs and pulley mods
Posted: Thu Mar 20, 2008 12:03 am
by SPREEtown
im looking to get heavier clutch springs for my spree, ive looked at the polini blacks, but my understanding is that they are too big? which ones should i get or should i have them made?
after grinding down my pulley i am ready to reassemble the the tranny, my question is about the placement of the washers: do they go on the front or rear pulley?
thanks, and i apologize if this info is on previous posts, but i havnt been able to find it.
Posted: Thu Mar 20, 2008 7:02 am
by stillspeeding
if the clutch springs go on hard then they will work, shims are used on the front pulley between the ramp & boss.
Posted: Thu Mar 20, 2008 9:38 am
by noiseguy
The washer you're referring to goes between the crankshaft and the inner pulley. Don't leave it out or you'll trash the crank.
Posted: Thu Mar 20, 2008 10:59 pm
by SPREEtown
thanks. im looking for better low end w/ the new springs, is there a brand out there that will fit spree clutches w/ or w/o mod to the clutch or springs?
Posted: Sun Mar 23, 2008 5:53 pm
by SPREEtown
anybody know if there are springs off the shelf? or if i should have some made??
Posted: Sun Mar 23, 2008 7:58 pm
by noiseguy
If you can find anyone that will make springs that small I'd like to know. I couldn't find anyone when I looked.
Posted: Mon Mar 24, 2008 12:12 am
by fireblade
There is a spring maker near me (not that thats any use to you guys) who makes all sorts of springs. I'd love to get some made, but how much stronger should I get them made? I don't want the clutch to do nothing untill 3/4 throttle, and then just grab really hard. Any suggestions?
It's going to cost me $35 a set to have them made (thats their minimum charge) so I wanna get it right 1st time.
It also just occoured to me, that with heavier springs, you'd lose engine breaking at a higher speed too.
