Still Smoking
Spyk
Still Smoking
Post by Spyk »
I changed the oil got it running good and just did a plug chop. The plug looks a good golden brown color like i am assuming it should but i still have quite a bit of smoke at high rpm's after a short distance. Any ideas?
Also thanks for all your help.
hondaman
Post by hondaman »
You said you changed the oil but what kind of oil did you put back in?
Spyk
Post by Spyk »
Genuine Honda 2-stroke injector oil.
do you think there is a chance that the oil may not have drained from the tank to the injector? i did change it about a week or so ago but haven't ran it much since...just a thought
Post by Kenny_McCormic »
Drive it for a while at high speed, probably s*** left behind by the old (im assuming it was crappy premix) burning off.
It will take a while to burn through the old oil. You'll need to dump the oil in tank and lines to get it all out, then refill with new oil and purge the air out per the Honda manual.
Spyk
Post by Spyk »
I did change all the oil out of the tank and line, but have not purged the air out of the lines so i will look into that next thanks!
berreta22
Post by berreta22 »
noiseguy wrote:It will take a while to burn through the old oil. You'll need to dump the oil in tank and lines to get it all out, then refill with new oil and purge the air out per the Honda manual.
This i know, cause mine smoked like a bug spray for like a half a mile, almost couldnt see me. Remember, the injection only drips every 5-10 secs so it takes a while to burn off.
