oil pump
HondaElite5094
oil pump
Post by HondaElite5094 »
I have a 1994 honda elite s and just got a high speed pully kit for it and i VT cycles told me that i can also get a larger jet size. open up the air box and tie the fuel pump open all the way. I was wondering if it being tied open all the way would foul the spark plug a lot? Has anyone done this?
also What is considered high revs for a stock elite motor? whats the highest they should be reving at?
1994 honda elite
gregr16
Post by gregr16 »
hi, not sure about the oil pump but the rpm should be.
At a stand still around 1800 to 2000 revs without throttle.
At high speed around 6000 to 7000 revs
This is for normal use of the scooter.
Dac
Post by Dac »
i did that oiler trick on my bike. It will make you smoke a little more/foul out plugs a little faster. But it is a 2 stroke so it will be doing that anyway.
One thing that is a must is good oil. Make sure you are using 2 stroke Injector oil. I recommend honda brand 2 stroke injector oil. GH2 or something like that.
Honda oil is really really good stuff. No much smoke, very little carbon build up, hardly ever goes though plugs.
I used honda for a while, then when i ran out i switched to Valvoline. total trash. Ill be buying honda brand again soon. It really is a huge difference.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
