On my '85 spree there shows to be no voltage at the terminals from the wiring harness.
Makes no difference whether the scooter is running or not.
Mike.
no voltage to choke terminals
Re: no voltage to choke terminals
Check for continuity from one end of the wires to the others. I bet you have a broken wire or loose connector.michaelg wrote:On my '85 spree there shows to be no voltage at the terminals from the wiring harness.
Mike.
That's it Gamemedic. Thanks.
