Starter question
Starter question
I put in a new battery and when you push the start button you only hear a clicking sound. What do I do to fix this problem??
- CharlotteSpreeRider
It happened to mine so dont rule it out entirley, rare..yes..but possible.CharlotteSpreeRider wrote:If battery is fully charged, and all you hear is a click, then you have a broken or loose wire. Rig the battery staight to the starter motor. If that doesn't fix it, the starter motor is hosed, which I've personally never heard of on Spree.
