UPDATE on Da-Scoot Paint & Speaker Encloser
da-scoot
Post by da-scoot »
Imagetore down
Imagewheels
ImageFoot Board
Imagelaid fiberglass over fleece
cut excess off
ImageThen sand
Imageadd bondo and sand... ALOT!!
Time to scuff all parts and spray PRIMER!!
Imageall parts in primer
Imageenclose in primer
Didnt like the pointed tip so we cut it off
we then laid a coat of texture coatin on floor board and enclosure... then used a Black Vinyl Dye to color them.. as a flat look to it to make it look more like a piece of plastic than a painted panel...
ImageSpeaker Enlcosure Finished
ImageWith speakers
Imagemock up
Time to paint the body panels Champion White
paint with no clear...
got the parts in clear now.. this is the only pic i took so far..
looks shiny!!
Well it will be rand to scuff and and then buff in 2 dayz... untill then im going to be running all the wiring for the amp, inverter, mp3 player, new battery wires, switches and i might throw on a red LED underglow on it..
Then it will be time to reassemble the beast!!
1987 Aero SB50P
All Show..No Go!
Champion White
Custom 5 1/4" Speaker Encloser
Eclipse Speakers
Sony Mp3 Player
Mitzu 650watt am
Dac
Post by Dac »
:D
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
burnt_toast
Post by burnt_toast »
Very nice, and good collection of pics!
Can't wait to see it all mounted, indash speakers look sweet
projects galore :nerd:
sfzoo
Post by sfzoo »
RAD!
GIJoeBob
Post by GIJoeBob »
What paint products are you using. I have tried several different paints and I have not really been satisfied with the results.
da-scoot
paint
Post by da-scoot »
GIJoeBob wrote:What paint products are you using. I have tried several different paints and I have not really been satisfied with the results.
i use a high build flexible primer from Napa..
Then I just has NAPA run Honda Champion White Paint code and had them mix a 1/4 of it..
Its just automotive paint... but u cant use it on plastic unless you use flexible primer... i.e any plastic bumper needs it..
And NAPA Clear Coat... the best they had... if you use a cheap clear coat it wil have a dingy yellow look to it and with White... its never good! lol
Thanks for the comments
Ill keep ya posted
1987 Aero SB50P
All Show..No Go!
Champion White
Eclipse Speakers
Sony Mp3 Player
Mitzu 650watt am
maddog
Post by maddog »
Alot of work for a spree :lol:
maddog
Post by maddog »
ooops! its not a spree thank god, its either an 89 or 94 elite.
GIJoeBob
Re: paint
Post by GIJoeBob »
Ill keep ya posted
Coolio!
Thanks man!
jstone
Post by jstone »
What did you use to get all the old paint off?
Dac
Post by Dac »
maddog wrote:Alot of work for a spree :lol:
lol, FAIL
those panels look nothing like spree panels.
Then, you said...
maddog wrote:ooops! its not a spree thank god, its either an 89 or 94 elite.
lol, for a second i thought you had it, then you Failed again.
its a an 88 SB50P.
da-scoot
paint
Post by da-scoot »
jstone wrote:What did you use to get all the old paint off?
i didnt take the paint off.. no need to.
Scuff the paint so the primer has somethin to grab on to..
1987 Aero SB50P
All Show..No Go!
Champion White
Eclipse Speakers
Sony Mp3 Player
Mitzu 650watt am
da-scoot
Post by da-scoot »
lol, FAIL
Then, you said...
its a an 88 SB50P.
YES IT IS alot of work!!
and way to much money! lol
But its unique and mine! lo
Correct it is an 88 elite s
1987 Aero SB50P
All Show..No Go!
Champion White
Eclipse Speakers
Sony Mp3 Player
Mitzu 650watt am
jstone
Post by jstone »
I know nothing about painting so help me out... If i painted over the plastic before then i'll need to remove that before i put the primer on right? And especially if it was black paint? Or does the lighter primer cover the darker paint?
eight08boy
is that
Post by eight08boy »
is that spray paint or gun if spray paint wut kind thanks alot
Gjino Kanahele
U asking cherry price u better have cherry s***
