1000RPM compresion spring
Posted: Tue Apr 15, 2008 1:18 pm
by scooter trash
do they make these for sprees and will i be sacraficing top speed if i put one on
Posted: Wed Apr 16, 2008 7:01 am
by maddog
if you put tighter cluch springs on you can build up the comp spring by using washers, find the o/d and go at least 1'4 it should help.
Posted: Wed Apr 16, 2008 3:41 pm
by Kenny_McCormic
Just shim it with washers as maddog suggested, it wont hurt top speed, your bike will just spool up a little longer before the clutch kicks in giving you better takeoff
Posted: Thu Apr 17, 2008 11:38 pm
by scooter trash
im a little lost. were do i put thse washers and do i need to buy new clutc springs :?: :?: :?:
Posted: Wed Apr 30, 2008 1:54 pm
by noiseguy
OK, now I'm confused. Why would change the compression spring on a Spree matter; there's no variator to change the pulley ratio?
Posted: Wed Apr 30, 2008 4:00 pm
by Kenny_McCormic
Lol good point, you dont need to change a spree compression spring, it just keeps the belt tensioned. You do however need to change the pull style springs on the clutch pads to change engagement RPM.
Posted: Thu May 01, 2008 1:56 am
by tru72
actually the center spring does way more than just keep the belt tension. The stiffer the center, the longer it will stay in its easiest gear, but to heavy of a spring it will never shift into high gear. Thats a common problem with people when they set their transmission up. So to your answer , yes a to heavy spring can damper your top end..
aloha
D
Posted: Thu May 01, 2008 8:10 pm
by Kenny_McCormic
tru72 wrote:actually the center spring does way more than just keep the belt tension. The stiffer the center, the longer it will stay in its easiest gear, but to heavy of a spring it will never shift into high gear. Thats a common problem with people when they set their transmission up. So to your answer , yes a to heavy spring can damper your top end..
aloha
D
But the spree is fixed gearing, the front pulley is just a solid chunk of metal and the belt never moves when you riding (you know what i mean).
Posted: Fri May 02, 2008 12:45 am
by tru72
my razz is like that , a fixed gear... I jus did a jog motor conversion for it. couldnt stand that slug of a motor in it!
aloha
D
