rusty gas tank question
Posted: Wed Apr 16, 2008 12:00 pm
by dukemartini
My 87 se50 sat outside for 10 years before i got it and the gas tank is covered in surface rust on the inside.
has anyone had any experience with coating the inside of a gas tank and how hard easy was it? i know this is a fairly common thing done to motorcycle tanks but i have no experience with it.
Posted: Wed Apr 16, 2008 11:47 pm
by mopedman
well one trick is to go get like 5 gals of gas and some new bolts and nuts and put a gal in and some bolts close it swish around for 5 min and repeat 4 or 5 times and it will be good
Posted: Thu Apr 17, 2008 12:36 am
by jstone
Unless the nuts/bolts make a spark... Noiseguy did a post on how to clean a gas tank out.
Posted: Thu Apr 17, 2008 11:34 am
by dukemartini
jstone wrote:Noiseguy did a post on how to clean a gas tank out.
Any idea where that post is? I've done a couple of searches and can't find anything.
Posted: Thu Apr 17, 2008 11:39 am
by CharlotteSpreeRider
dukemartini wrote: Any idea where that post is? I've done a couple of searches and can't find anything.
http://www.hondaspree.net/phpBB2/viewtopic.php?t=5
Posted: Thu Apr 17, 2008 11:41 am
by dukemartini
thanks
Posted: Fri Apr 18, 2008 8:23 pm
by noiseguy
Man that is an OLD post. Technique worked great for me, though, and the tank's still clean after a few years.
I've read up on tank coating... unless you have holes through the tank (and can't get a new one) it's just not worth it... carb gets filled up with tank sealer instead of rust.
De rusting a tank
Posted: Fri Apr 25, 2008 11:44 am
by Curly
Duker,
I just de-rusted my tank with a product called Evapo-Rust. You can purchase it online or at most Autozone stores. It works real well and can be reused. When you are done using it in your tank pour it through a coffee filter back into the container to save it for future. Be sure to use a good degreaser before you let the Evapo-rust sit for a few days.
-Curly
Posted: Fri Apr 25, 2008 12:13 pm
by dukemartini
I'll check that out, thanks Curly
