SOO *
SOO *
well i was out crizin on the spree today and all of a sudden the spree just died. so, i turned the key and the engine sounded like it had no compression.not music to my ears after just paying $150 2 days before to rebuild it. i think i blew a head gasket because oil got past the seal when i looked at it. i also sanded the head down to smooth it out because it was scratched with very,very,very, fine sandpaper.
87' spree (SOLD
12' wrx
87' spree (SOLD
12' wrx
- burnt_toast
it just seems so familiar as if i was pulling the engine apart 2 DAYS AGO!this sucks. is there a certain way the head gasket should go on?
87' spree (SOLD
12' wrx
87' spree (SOLD
12' wrx
- burnt_toast
- burnt_toast
oh i forgot. i didnt recieve a base gasket(jug to eng) so i used that gasket maker stuff that comes in the tube. but i dont think it holds compression that far down. could this be a problem?
87' spree (SOLD
12' wrx
87' spree (SOLD
12' wrx
its a good Idea to always use a new base gasket and head gasket all the time when rebuilding. I also use the products below, Gasket remover to take all the gummy stuff left prior to rebuilding and I lightly spray each gasket on both sides with copper spray gasket high temp to make sure no leaks. torque each head bolt to 10lbs criss cross
http://www.permatex.com/products/prodid ... m_no=80696
http://www.permatex.com/motorcycle/RecP ... m_no=80646
- burnt_toast
not at all. nothing to do with it.i dont think the rings went either because they are brand new and it just died all of a sudden. no loss of porer or anything, it just died. so thats why i think its a head gasket.
87' spree (SOLD
12' wrx
87' spree (SOLD
12' wrx
- burnt_toast
but still only 5psi? maybe you have a stripped bolt? hopefully not, since that could be a real pain. did flipping the gasket help any?vette76 wrote:not at all. nothing to do with it.i dont think the rings went either because they are brand new and it just died all of a sudden. no loss of porer or anything, it just died. so thats why i think its a head gasket.
projects galore
