lol....i want all of your opinion!
Posted: Sun Apr 20, 2008 8:15 pm
by chevyguyjay
lol, heres something im ganna do. never did one before. im ganna build a 85 spree engine using ALL used parts. everything down to the used crank seals and crank bearings. ill still make some gaskets, but im even ganna use the old head gasket. used piston rings, everything. i think i have a good chance in getting the engine to run......but how good.........i dont even know. :?
Posted: Sun Apr 20, 2008 8:21 pm
by mopedman
we have did that before but normally i don't work out too well
Posted: Sun Apr 20, 2008 8:28 pm
by Kenny_McCormic
Port the exhaust, shave the head and port the intake manifold while your in there. I recomend you at least buy new rings and hone the jug.
Posted: Sun Apr 20, 2008 8:32 pm
by chevyguyjay
oh no....all used. i might give the cylinder a quick hone. that all. :wink:
Posted: Sun Apr 20, 2008 9:33 pm
by Kenny_McCormic
Well port it out and see what happens seeing as its a "junk" motor.
Posted: Sun Apr 20, 2008 9:42 pm
by burnt_toast
what is the point of this half-assness?? :?
Posted: Sun Apr 20, 2008 11:02 pm
by berreta22
I Blew up my bike..2nd time..so i bought used rings and piston and jug..had 2300 miles on it..slapped it all together and runs great. Got 32 mph with it..now i get 25..im sure my 285 lb butt isnt helping matters any but thats my story.
Posted: Mon Apr 21, 2008 12:35 am
by chevyguyjay
all my point is, is that i never put engines together with all used stuff. im sure others on here have, and wanted to c what the results were. :wink:
Posted: Mon Apr 21, 2008 1:51 am
by burnt_toast
I personally dont see the logic, wether it works or not its gonna be a pos and wont last. In that aspect, this seems like a waste of time..
but to each his own i guess
Posted: Mon Apr 21, 2008 11:36 am
by greg_bingham
do it.
half-assing is it's own reward, and these aren't exactly F1 engines, are they?
just give that jug a scuff, slap it together and see what happens? whats the worst that could happen? air leak, crank bearing seizes, crank twists, rod bends breaks snd shoots through the cases..
oh wait a minute this isn't a jetski..
it'll likely run slow, maybe run lean and seize.. more likely it will run EXACTLY like it would have if you'd thrown all new parts at it.
i've rigged ski motors together in this fashion (with a strict 'not responsible if it blows' understainding) for people and they ran like a champ..
you're just eliminating the likelihood of leaks and such with new parts. the old ones may work just as well..
Posted: Mon Apr 21, 2008 2:42 pm
by berreta22
berreta22 wrote:I Blew up my bike..2nd time..so i bought used rings and piston and jug..had 2300 miles on it..slapped it all together and runs great. Got 32 mph with it..now i get 25..im sure my 285 lb butt isnt helping matters any but thats my story.
I forgot to mention i didnt even use head or jug base gaskets either. Considering how easy it is to rebuild one, thats why i half assed mine..now if it was a 2 day project..well * i still might have done it..its neat to see how used parts that didnt wear together work together.
Posted: Mon Apr 21, 2008 4:51 pm
by GIJoeBob
I don't see a difference between building a scooter from used parts and cleaning up a used scooter and getting it running. The parts in either case are used.
All my scoots are used and run great, well except for my Spree that I screwed up. :roll: :lol:
Posted: Mon Apr 21, 2008 7:15 pm
by greg_bingham
the difference is he's proposing to build a unit with gaskets that have been compromised by deing dis-and re- assembled (subjected to compression) versus a unit that has been 'run-in' components wearing together... with gaskets that were fresh when installed...
greg
Posted: Mon Apr 21, 2008 9:02 pm
by GIJoeBob
greg_bingham wrote:the difference is he's proposing to build a unit with gaskets that have been compromised by deing dis-and re- assembled (subjected to compression) versus a unit that has been 'run-in' components wearing together... with gaskets that were fresh when installed...
greg
Yeah, just like some of my scoots.
