perfornace technical
bigmac
Post by bigmac »
hi have1998 elite50 with 72 cc corsa bore kit and 21 mm carb oko will a pg yoshimura work on it i was told i need a28 mm carb to work right on this kit thanks bob[
burnt_toast
Post by burnt_toast »
Yes, but its a low rev pipe, corsa likes revs so you may want something thats more of an expansion chamber.
projects galore :nerd:
tru72
Post by tru72 »
yosh pipes are more for 90cc. its a little much for a 72, you wont get any top end from it. 21mm carb wil work fine. Your better off with a pg long. Thats a pretty easy pipe to set up. Do you have any gears?
aloha
D
maddog
Post by maddog »
What gear ratio do you have, the pipe & carb can be tuned to the gears then the trans.
