idle and air screw What am I missing?
Posted: Sun Apr 27, 2008 7:36 pm
by rpm9001
I just got done cleaning my carb on my 1995 sa50s and when I took out the air and idle needle/ adjusted screws I must not of noticed the springs and or washers behind them. If they were in there I must of blasted them with air not knowing they were in there.
All I have is the 2 needle adjusted needles and one spring. I looks at the parts brake down on bike bandit and it looks like I should have 2 springs and maybe a washer...
What should I have? It was hard to tell on the parts list.
Trying to figure what I'm missing.
Thanks
Anyone have a old carb? I would buy what ever I'm missing or the whold carb
Posted: Sun Apr 27, 2008 8:46 pm
by buildbyflying
I'm cleaning the carb on my aero (spree) and mine's the same. The spring came from the idle needle, not from the drain needle.
Posted: Mon Apr 28, 2008 2:18 pm
by rpm9001
There is 2 needles on the carb, not in cluding the drain screw. I believe both of them have springs.
Posted: Sun May 04, 2008 9:29 am
by justinnielsen01
you should have 3 screws facing out that adjust
Posted: Sun May 04, 2008 10:55 am
by rpm9001
I know how many their is, I got it now, Their is also orings, small washers, and springs on the needle. I did not realize they were stuck in the opening when I put it in the parts washer. I just ordered a new kit. runs great now.
