86 Spree has power, but won't start
heavywear
Post by heavywear »
fresh battery and all I get is tail lights and blinkers. No engine turn whatsoever. Frozen starter? Fuse? Kickstart is missing so maybe I should pick one up to start that way? any advice is appreciated, thanks :(
Post by Kenny_McCormic »
It wont work without a belt cover as it holds the starter gears together.
chevyguyjay
Post by chevyguyjay »
check the fuse. if good, check the relay. if good, check the wire clip going to the starter. check the grounds. if still no go......remove the starter and check it. :wink:
~2004 Geely Fashion~
justinnielsen01
Post by justinnielsen01 »
put starting fluid in your spark plug hole then put it back on and kick start it when you get a new one dont give it any gas
