Got Piccies!!!!
So hopefully you can give me an idea of the year from that.. I hope i got everything relevant.
On the upside, I've managed to progress, and its almost road legal. I got it registered (as an 88), fitted wing mirrors, filled, charged and fitted the battery, tested electrics and cut the vinyl to re-upholster the seat.
Found that I have a front left indicator out and the bulb looks good, so I have to trace back and find the problem there. the fuel guage may also be bust.
Also looks like I need to straighten the left hand leg of the stand as its forward of the right one and I've had it scrape to ground a few times when I've been cornering.
Outstanding questions...
Year? (a label I found under the seat says its an NQ50M if that helps any..)
Indicators... is it supposed to beep when the indicators are on, or have i got a short to the horn?
Air scoop.. what difference will this make?
thanks in advance
Dave
