wet spark plug
cpiunno
wet spark plug
Post by cpiunno »
What does it mean when I put a new spark plug in, I am able to run at WOT for only about 15 seconds and then it will die if I try to give it any gas (it will still idle ok.) Pulled the plug and it's soaked with oil/fuel. Tried it again, same thing happened.
Note: Bike ran perfectly before I put on aftermarket filter and ported intake manifold. I would think this would make it run lean, though.
-Carmen
CharlotteSpreeRider
Post by CharlotteSpreeRider »
Float getting stuck in carb?
-aseigler
cpiunno
Post by cpiunno »
Also, I sprayed Mopar Combusion Chamber Cleaner in the intake, is it possible I sprayed too much too quick and damaged something?
-Carmen
danmdevries
Post by danmdevries »
Air filter dirty/clogged?
2004 Kymco ZX50
70cc kit, 19mm carb, chambered exhaust
cpiunno
Post by cpiunno »
It's a brand new air filter. I suppose it could be faulty.
-Carmen
Post by Kenny_McCormic »
Check that the lid is not clogged up.
