ferchja
Posts: 187 Joined: Mon Jul 23, 1973 10:24 am
Post
by ferchja » Wed May 04, 2005 9:54 pm
There are two ring sets listed on the part fish, other than the oversizes. One is called "Rings, Piston" and the other is "Rings (STD)" I have both cause the local part counter screwed up the order. Which do you think is the stock set? I don't want to open them cause I don't think I can return it to them.
I assume those who have ordered rings can tell me the difference or enlighten me as to why there are two sets with what seem to be the same name.
Thanks in advance
Jeremy
85 Spree
vette76
Posts: 1830 Joined: Sat Jul 31, 2004 8:00 pm
Post
by vette76 » Wed May 04, 2005 9:59 pm
iwould guess "rings, piston would be it at long as it doesnt say oversized,or whatever.then again std can stand for stock diameter, so i wouldnt kno.
87' spree (SOLD
12' wrx
ferchja
Post
by ferchja » Wed May 04, 2005 10:25 pm
The part guy couldn't tell me either....it's a mystery.
Anyone order rings here recently? What is the part number you ordered? I will match to what I have and go with the concensus.
Thanks
Jeremy
vette76
Post
by vette76 » Wed May 04, 2005 10:50 pm
i would let u kno but i had .50 over and u have stock rite?
87' spree (SOLD
12' wrx
ferchja
Post
by ferchja » Thu May 05, 2005 8:32 am
Correct, mine is stock.
burnt_toast
Posts: 3469 Joined: Sat Jul 31, 2004 8:00 pm
Post
by burnt_toast » Thu May 05, 2005 1:38 pm
if you still need to know, i can check out my box where i have the stuff from my last rebuild. i dont think i threw away the ring box so it may have the part number on there. let me know.
projects galore
nester
Posts: 8 Joined: Mon Jul 23, 1973 10:24 am
Post
by nester » Thu May 05, 2005 2:27 pm
I can get you the part number for stock rings, but it's in my other car. I'll check when I get home tonight.
ferchja
Post
by ferchja » Thu May 05, 2005 3:41 pm
Thanks guys! Once I see what part numbers worked for you, I will be more confident to return the other one.
Jeremy
burnt_toast
Post
by burnt_toast » Fri May 06, 2005 12:36 am
its in the middle of the night, but i decided to go find that box, lol.
i got the rings from the dealership, so this should be the stock #:
13011-GAB-305
tell me if thats one of the ones you got.
projects galore
ferchja
Post
by ferchja » Fri May 06, 2005 11:30 am
Yep, that is what I think the replacement number is. I have the 305s
burnt_toast
Post
by burnt_toast » Sun May 08, 2005 12:59 am
ok cool, glad i could help u out.
projects galore
