Elite 50 performance mods
gobucks
Post by gobucks »
hey, just looking for some easy non-bore kit mods.
I heard that changing the stock CDI for a free reving CDI will increase the top speed, is it true?
Also i heard that drilling a hole in part of the muffler will help increase power, what part do you drill it in?
Jacobusmaximus
yyep
Post by Jacobusmaximus »
I know for a fact that drilling a hole in the muffler impproves torque and top speed (minutly). THe point is to drill out the restriction plate that only lets a certain amount of airflow out. the more airflow going out the more power ur gonna get.
As for the CDI, I have no idea. I saw them on ebay. something about unlocking your engine. I'm not sure. looks promising! but get a second opinion.
Yamaha Aerox 50 WANTED!
CharlotteSpreeRider
Re: yyep
Post by CharlotteSpreeRider »
Jacobusmaximus wrote:the more airflow going out the more power ur gonna get.
To a point. 2 strokes need backpressure to operate. When there is positive pressure in the cylinder the pressure is released to the exhaust and is prevented from going back into the carb by the reed valve. When there is negative pressure in the cylinder, gas filled air should be sucked in through the reed valve and not the exhaust. If the backpressure on the exhaust too low, the engine will pull too much air from the exhaust port and not enough from the intake port, and the engine will run lean or not run at all.
-aseigler
devenex
Post by devenex »
Drilling into the baffles will also make the scooter louder. Not a big deal, but if you prefer quieter it may not be the best option.
1986 Spree w/ '87 SE50 motor
mopedman
Post by mopedman »
yea it dos make it a bit louder
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
Post by Kenny_McCormic »
You shove a long drill bit in the back hole where the exhaust comes out, drill 2 restrictions. What do you have?
gobucks
Post by gobucks »
how would you increase the top speed most effectively on a Elite SA50?
what year?
Dac
Post by Dac »
gobucks wrote:how would you increase the top speed most effectively on a Elite SA50?
What year is it dude?
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
gobucks
Post by gobucks »
95 elite
Gears and a bore kit.
Gamemedic
Post by Gamemedic »
Did you drill out the washer in the front of the exhaust pipe and take out the spacer plate on the front clutch?
gobucks
Post by gobucks »
i did drill out the muffler, but not the clutch, how do you do that to the clutch?
Gamemedic
Post by Gamemedic »
Take the covers off the clutch and unbolt the front clutch. On the back of the inner race there is a plate with 3 6mm bolts holding it on. Unbolt the plate and toss it aside. Reassemble. There is a thread on here about it.
Dac
Post by Dac »
dude i got one word...
Gears!
8.44:1 gears! Right now im running 8.44:1 gears in my bike (same motor as yours) with great results. The take off is still good and the top speed is allot higher.
See, i had a 72cc bore and gears. But i blew up more bore kit. So i left the gears and put my stock cylinder back on. The bike still has good take off and the top speed is d*** near 50mph (given it takes some time to get up to top speed).
