shaving the front pulley?
zoom
Post by zoom »
Now exactly what am i supposed to do? And what eaxactlky an i supposed to file, thers two things that came out and how much am i supposaed to file?
thanks
vette76
Post by vette76 »
the inner pulley is the one u want to shave. take about 1/16 off the inner pulley to decrease the gap between the inner+outer pulley.
87' spree (SOLD
12' wrx
darat
Post by darat »
so how much more speed would u get by doing this
vette76
Post by vette76 »
i got like 2mph more. the thing that sux is u lose bottomend. u cant do this with the elite because u have a variator in that.
87' spree (SOLD
12' wrx
darat
Post by darat »
ok this sounds kinda of dumb but what is a variator. i know what it does but is it a good thing
vette76
Post by vette76 »
yes. it changes the ratio so its kind of like 2 speeds but you cant feel it shift.that is why the elite is faster then the spree.
87' spree (SOLD
12' wrx
Darat: Pull the sidecovers on your Spree and Elite. The Elite has a variator. It works like the trans on a snow mobile, tightening the front pulley halves at higher RPM.
You want to shave about 1/32" (.030"). Use a piece of plate glass and 220 wet-dry sandpaper with water if you don't have access to a mill. Use a measured paperclip through the hole of the pulley half to gauge progress. You can buy steel rulers marked in 1/32", which is about as close as you can see without a magnifying glass. A slide micrometer would be better.
darat
Post by darat »
so which is better the spree trans or the elite?
vette76
Post by vette76 »
elite. its like whats better 1 speed or 2.
87' spree (SOLD
12' wrx
zoom
Post by zoom »
so the spree only has one gear. cuz when i would drive mine it would kind of feel like it shifted into second.
vette76
Post by vette76 »
no all sprees are like that. the strongest part of 2 strokes are mid+upper range power. that is just the engine getting past that low rpm hesitation.
87' spree (SOLD
12' wrx
zoom
Post by zoom »
ohhhh
peter1sp
Post by peter1sp »
vette76 wrote:yes. it changes the ratio so its kind of like 2 speeds but you cant feel it shift.that is why the elite is faster then the spree.
Hey is there any way to put one of the variators in the Spree? A Tranny would be nice in the spree or atleast fun to try.
1981 CM400 C... Former Rides: 1986 Honda NQ50
vette76
Post by vette76 »
i believe noiseguy tried this, and i didnt fit. u would have to also change the crank.
87' spree (SOLD
12' wrx
The '84 Spree is different enough from the Aero that the variator from it will not fit; I believe these differences extend to '86. The '87, though, looks like it has a different front pulley setup. I think that the variator may bolt up to the '87. But Vette76 never sent me the dimensions to check. Since Vette76 has an Elite now, he should be able to look at both and see if it will bolt up.... :D
