Few more mph for Honda Elite 50
I just got my hands on a 1987 Honda Elite 50. It says that it only gets up to 30 mph. I wondering if there was anything that I could do to get it up to 40-45 mph. I don't have a lot of expertise in this sort of thing, and I don't want to spend much money on it, but I am sure a couple friends and I can do some simple modifications. Thank you.
Drill two plates form the muffler (put a drill in the tip and drill 2 plates, sounds like a dirtbike and helps everything a little). After that you need an impact gun to remove the drive pulley (under the engine cover on the left side) and check if there is a plate on the back held on with 3 bolts.
- justinnielsen01
de ristrict the exhaust and get a high speed variator with 9 gram rollers heres one on ebay that i got http://cgi.ebay.com/ebaymotors/RACE-VAR ... enameZWD1V
Im looking at getting this one in ebay http://cgi.ebay.com/ebaymotors/_ATV-Par ... 0227491338&
It comes with 3 sets of weights, what would be the end results (pros & cons) of using lighter vs. heavier weights?
You can adjust the timing manually as well with some modifications.jwasciuk wrote:So this auction looks good cuz it would allow me to try 7g, 9g or 10g weights correct?
What does timing have to do with this???noiseguy wrote:You can adjust the timing manually as well with some modifications.jwasciuk wrote:So this auction looks good cuz it would allow me to try 7g, 9g or 10g weights correct?
Noob Questions
This is going to be a noob question, but what does a racing variator do?... is it similar to getting a lightweight flywheel on a car?
Re: Noob Questions
the ramp is different.nparks wrote:This is going to be a noob question, but what does a racing variator do?... is it similar to getting a lightweight flywheel on a car?
better angle for take off, and bigger overall size to get better top end.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
- justinnielsen01
