how to decarbonize the exhaust???
snowdaze00
Post by snowdaze00 »
How do you guys unplug the exhaust. I have always just built a fire and burn the pipe. Or at least it has worked on the small four wheelers and other 2 stroke pipes.
Has anyone ever cut their spree pipe in half and just gutted the inside and then weld it back together??
Thanks,
snowdaze
Post by Kenny_McCormic »
Gutting will cause s*** like running, needs more back pressure, you want to drill 2 baffles for best performance.
po89mm
Post by po89mm »
you got 2 choices:
1. fire
ie, take a torch to it and burn the garbage out (takes a bit of skill) or toss the whole thing in a camp fire.
2. chemical
ie,submerging the entire mufler in a solvent solution such as oven cleaner, gunk or lye.
Ive personally used lye crystals,
usually available in the plumbing section of the local hardware store with steller results.
snowdaze00
I did the fire pit - runs best it ever has now.
Capohanf
Oven cleaner???
Post by Capohanf »
How well does the oven cleaner work? I have a Suzuki FA50 that is carboned from spark plug (carbon short across the spark gap) to tail pipe but I do NOT want to mess with the cylander if possible except to maybe remove the head and scrape the top of the pistion. Have the muffler off so access to the exaust port is easy.
Re: Oven cleaner???
Capohanf wrote:How well does the oven cleaner work? I have a Suzuki FA50 that is carboned from spark plug (carbon short across the spark gap) to tail pipe but I do NOT want to mess with the cylander if possible except to maybe remove the head and scrape the top of the pistion. Have the muffler off so access to the exaust port is easy.
Burn/lye the muffler and reinstall it, instructions in technical documents subforum. Put the muffler back on and go buy some seafoam from a parts store. Start the bike, have a buddy hold the throttle pretty close to wide open, slowly pour the seafoam in the intake with the airfilter off you might need to choke the engine with your hand to keep it running, dont pour in so much the engine dies, do this till you used around a 1/4 can. IDK how well this works but people that do it say it cleans all the carbon out of the combustion chamber.
justinnielsen01
Post by justinnielsen01 »
camp fire rocks
teeoce
Post by teeoce »
how long do you leave the exhaust in the campfire?
gobucks
Post by gobucks »
til the fire goes out
dr.ona
Post by dr.ona »
Or the keg is empty! :lol:
"I can't drive......35!"
brad_659
Post by brad_659 »
i drilled the baffles and now there is more crap in there...i plan to soak mine in somthing good and them do the fire trick to burn off all of that...i will post the response from that.
