mxallred
Posts: 8 Joined: Sat May 24, 2008 9:23 pm
Post
by mxallred » Sat May 31, 2008 7:25 pm
yeah it doesnt seem to run under 15. but one it gets over 15 it takes off. could this be in need of a carburator clean?
'86 spree-35 mph on 50/50 c12 and premium
Posts: 4957 Joined: Sun Apr 16, 2006 11:51 am
Post
by Kenny_McCormic » Sat May 31, 2008 8:58 pm
Clean carb, air filter(replace if not half inch thick and spongy), and clean two ports on airbox lid. Do a plug chop.
mxallred
Post
by mxallred » Sat May 31, 2008 9:19 pm
yeah the filter fell apart when i took it out so i am just running it with out one untill i can get a new one. what is a plug chop?
CharlotteSpreeRider
Posts: 710 Joined: Tue Sep 11, 2007 2:13 pm
Post
by CharlotteSpreeRider » Sat May 31, 2008 9:42 pm
Stop right there. Don't run it again until you get a filter, AND clean out the air box and the carb. You run the risk of frying the motor running without a filter, and undoubtedly your carb has sucked in some of the old filter (bad).
-aseigler
Post
by Kenny_McCormic » Sat May 31, 2008 9:54 pm
The motor will run lean and slowly melt internally if run without a filter not to mention all the dirt and bugs it will suck in.
mxallred
Post
by mxallred » Sat May 31, 2008 10:13 pm
alrite ill have to pull one out of another spree..
Post
by Kenny_McCormic » Sat May 31, 2008 11:41 pm
Its $4 at any Honda quad/motorcycle shop.
