86 spree bogs untill you hit 15
Posted: Sat May 31, 2008 7:25 pm
by mxallred
yeah it doesnt seem to run under 15. but one it gets over 15 it takes off. could this be in need of a carburator clean?
Posted: Sat May 31, 2008 8:58 pm
by Kenny_McCormic
Clean carb, air filter(replace if not half inch thick and spongy), and clean two ports on airbox lid. Do a plug chop.
Posted: Sat May 31, 2008 9:19 pm
by mxallred
yeah the filter fell apart when i took it out so i am just running it with out one untill i can get a new one. what is a plug chop?
Posted: Sat May 31, 2008 9:42 pm
by CharlotteSpreeRider
Stop right there. Don't run it again until you get a filter, AND clean out the air box and the carb. You run the risk of frying the motor running without a filter, and undoubtedly your carb has sucked in some of the old filter (bad).
-aseigler
Posted: Sat May 31, 2008 9:54 pm
by Kenny_McCormic
The motor will run lean and slowly melt internally if run without a filter not to mention all the dirt and bugs it will suck in.
Posted: Sat May 31, 2008 10:13 pm
by mxallred
alrite ill have to pull one out of another spree..
Posted: Sat May 31, 2008 11:41 pm
by Kenny_McCormic
Its $4 at any Honda quad/motorcycle shop.
